Текущее время: 17 окт 2026, 21:12
Начать новую тему Ответить на тему  [ Сообщений: 79 ]  На страницу Пред.  1, 2, 3, 4  След.
 Заголовок сообщения: Re: greeting from Egypt
СообщениеДобавлено: 18 мар 2013, 18:37
So i don't need to change the shock absorber
For replacing 12" wheels to 13" don't needs change.
Part no. for front shock absorbers - Monroe MG886. Front coil spring - KYB (aka Kayaba) RA1906. Rear shock absorber - Monroe 22701, rear coil spring - KYB RA5651. You may change these parts if exsisting are damaged.
Thank you i go to the internet site of monroe and i couldn't find its link secondly i want the link of coil spring and what KYB (aka kayaba) mean Thank you waiting for your reply
СообщениеДобавлено: 18 мар 2013, 21:47
Sorry, here i can't help you. There are many shops sells these parts in our Country. How find them in your - i don't know.
СообщениеДобавлено: 16 мар 2014, 04:01
does the engine of 21083 fit oka
СообщениеДобавлено: 16 мар 2014, 15:21
Yes. But this is a difficult job. It takes a lot of welding, alteration engine subframe, body panels and semiaxes. Perhaps something else.
http://photoshare.ru/album138030.html
http://photoshare.ru/album137909.html
It might be easier to install the engine Daewoo Tico, Daewoo Matiz, Suzuki Alto or similar 3-cylinder, 800...900 cc.
СообщениеДобавлено: 16 мар 2014, 21:03
Авто: СеАЗ-11113
Про двигатель Матиза можно забыть - это тупик. Тико - вероятно возможно. Альто его прародитель, тоже вероятно возможно.
СообщениеДобавлено: 30 мар 2014, 16:29
thank you but which is better Daewoo Matiz or Suzuki Alto and which is better fit directly. does there are also welding operations
СообщениеДобавлено: 30 мар 2014, 16:45
does Maruti Alto engine fit. which one{ Engine 796 cc (0.8 L) F8D I3 (petrol) 998 cc (1.0 L) K10B I3 (petrol) 1,061 cc (1.1 L) F10D I4 (petrol)}
СообщениеДобавлено: 30 мар 2014, 16:46
СообщениеДобавлено: 30 мар 2014, 17:44
Dr amir Lala, Maruti Alto (F8D l3, 798 cc) is Suzuki Alto, Daewoo Tico and my BYD Flyer (model QCJ7083, engine HH368QA1). Oka-11116 (engine TJ376QE) is similar to K10B (l3 998 cc).
I think, it's possible with any of these l3 engines. But don't forget about subframe, gearbox, drives and ECU (BYD Flyer have injector, ECU is Bosch m1.5.4 0-961-206-925, Oka-11116 have similar ECU). All these engines are smaller than 21083, and I hope that there will be less welding (maybe only need to rework the semiaxes, exhaust pipes, mount steering gear to subframe and mount subframe to body).
михмех, а в чем может быть проблема с Матизом?
СообщениеДобавлено: 30 мар 2014, 22:00
Авто: СеАЗ-11113
Один из форумчан затеял подобный проект и советовался со мной.
У него возникли проблемы, основная - высота двигателя. Рессивер находится у Матиза высоко над клапанной крышкой. Он опустил подрамник на 40 мм, но и этого не хватило. Внутренний левый ШРУС оказываются в том месте, где должна быть точка приложения нижнего левого рычага, правый привод получается очень длинным и проходит через правую часть подрамника, при этом приёмная труба глушителя пересекает переднюю поперечину подрамника. В итоге, порезав родной подрамник и покрутившись вокруг около полугода, он забросил эту затею и вроде распродаёт останки.
Тико и Альто карбюраторные, их мотор можно поднимать гораздо выше.
P.S.
Ребята, вы бы писали не только на английском, но и на русском. Я кое-как с переводчиком разбираю общий смысл, последние сообщения вообще не понял.
СообщениеДобавлено: 31 мар 2014, 00:33
[ImgShow][/ImgShow]
27aff44s-480.jpg [ 47.91 КБ | Просмотров: 17589 ]
3c1ff44s-480.jpg [ 55.13 КБ | Просмотров: 17589 ]
how this man change the size of tires like that
СообщениеДобавлено: 31 мар 2014, 00:37
Вот если бы у меня был вопрос с выбором двигателя,наверно просто поставил от мото.Компактный и мощный.Проблем на много меньше.
СообщениеДобавлено: 31 мар 2014, 00:50
Ой.. Перевожу (грубовато, но с сохранением смысла):
Спасибо, но какой лучше: Матиз или Альто и какой лучше подойдет? Там тоже потребуется сварка?
Подойдет ли Maruti Alto? Какой именно (F8D 3ц 0.8 л, K10b 3ц 1 л, F10d 4ц 1.1 л)?
Maruti Alto (F8D, 3ц 0.8л) - это Suzuki Alto, Daewoo Tico и мой BYD Flyer (модель QCJ7083, двигатель HH368). Ока-11116 (двигатель TJ376QE) аналогичен K10b (3ц 1л).
Думаю, это возможно со всеми этими 3ц двигателями. Но не стоит забывать о подрамнике, КПП, приводах и ЭБУ (Flyer - инжектор, ЭБУ Bosch m1.5.4, у 11116 - аналогичный ЭБУ). Все эти двигатели меньше 21083, и я надеюсь, что сварочных работ будет меньше (может быть только переделка полуосей, выхлопа, крепления рейки к подрамнику и крепления подрамника к кузову).
Тогда и у инжекторного преемника Альто (BYD Flyer) может быть та же проблема. Хотя я бы не сказал, что ресивер там очень высоко расположен: он скорее за клапанной крышкой, а не над ней. А сам двигатель можно сдвинуть почти вплотную к моторному щиту: генератор (в отличие от Матиза) установлен спереди, а больше там вроде бы нет ничего, сильно выступающего. Вот с двигателем 11116 может получиться хуже, он больше напоминает Матизовый. Но ведь как-то втиснули его на СеАЗе...
А приемная труба вроде бы у всех этих двигателей одинаково расположена: на продольной оси машины, перед двигателем, с подвижным уплотнением (полусфера с прокладкой из металлической сетки с пропиткой и подпружиненные болты, притягивающие трубу к коллектору, ох и намучался я с этим местом).
Насчет ШРУСов я как-то не подумал, что они могут оказаться не в том месте.
Если надо, могу сделать какие-нибудь замеры и (или) фото своего двигателя. Но только то, что видно с открытым капотом: ямы или эстакады поблизости нет.
PS. Тоже иногда обращаюсь к переводчику за подсказками. Наиболее адекватным показался Google: http://translate.google.com/
Probably, he replaced or reworked springs, shock absorbers, semiaxes, hubs, steering and brake mechanisms.
Kolhoznik, а ведь прецедент уже есть:
http://www.youtube.com/watch?v=Lmcnh0MUSO8
http://www.youtube.com/watch?v=tagbYEb6JRs
СообщениеДобавлено: 31 мар 2014, 23:26
Авто: СеАЗ-11113
Самой выступающей частью является КПП. По словам всё того же товарища, она сильно широкая и с этим ничего не поделать.
Кстати, Ока с двигателем Матиза существует, и это не самоделка, а заводской вариант. Только дорожный просвет у неё, видимо, уменьшен до нельзя.
http://me.stormway.ru/photos/exibitions/MiMS03/oka/
СообщениеДобавлено: 01 апр 2014, 22:56
Thank you my friends . okay now to change my tire size to r13 and change for (four nut). I will buy the rear break drum for Lada 2108. what i have to do for the front. give me your advice.
СообщениеДобавлено: 02 апр 2014, 20:27
You can use the front hub from 11116, or drill old hubs on the 4 holes.
СообщениеДобавлено: 03 апр 2014, 03:23
we don't have here in Egypt any spare part from 11116 . does the front old hubs able to bear r13 rim
СообщениеДобавлено: 03 апр 2014, 20:42
Yes.
СообщениеДобавлено: 05 апр 2014, 15:13
okay does there any dimension needed for the rim r13 for example (does the rim dimension has to be 4 *98)
