Текущее время: 16 окт 2026, 11:30
Начать новую тему Ответить на тему  [ Сообщений: 79 ]  На страницу Пред.  1, 2, 3, 4
 Заголовок сообщения: Re: greeting from Egypt
СообщениеДобавлено: 13 апр 2014, 23:00
how are you Aquinas. unfortunately, every possible try with you to change from r12 to r 13 is impossible now. no parts are ready and fit to take from other type of cars and put it directly to oka 1113
СообщениеДобавлено: 14 апр 2014, 00:46
Thanks, I'm fine. But tired after fix and replace damaged outer C.V. joint on Flyer. And I couldn't shoot both cars, 'cause I couldn't start Oka's engine (I haven't time to understand, why engine isn't starting).
I think, it's no easy methods to change R12 to R13. Easiest is - to find Citroen AX R13 wheels. Most dimensions of them are same to R12 Oka's wheels, and You must just make spacers for them. Spacer is a steel washer or ring between wheel and hub, it can be made on a lathe.
Next method is to find R13 kit for 11116 (hubs, drums and brake disks), as Automaster advised.
Other methods are require to replace and rework many parts and therefore they are difficult.
СообщениеДобавлено: 22 апр 2014, 18:24
i could find in my country the Tyre size 155/80 r12 . what do you think. does this Tyre size fit to Oka. does this Tyre size cause any harm for the car.
СообщениеДобавлено: 22 апр 2014, 18:34
СообщениеДобавлено: 22 апр 2014, 18:54
Yes, this size is fit to Oka. I have 165/75 R12 (summer) and 145/80 R12 (winter) tyres and I haven't troubles with them.
СообщениеДобавлено: 24 апр 2014, 00:57
thank you . But you don't make change to your car from r12 to r 13. okay i want to see a photo for your car in Tyre size 165/75 r12
СообщениеДобавлено: 24 апр 2014, 22:04
СообщениеДобавлено: 24 апр 2014, 22:27
Ok, I'll make photo as fast as I can (maybe, saturday or sunday, but not earlier).
СообщениеДобавлено: 25 апр 2014, 18:25
thank you
СообщениеДобавлено: 27 апр 2014, 13:57
how are you , my oka car consume a lot of fuel as i think. 110 km/ 11.5 liter. What is the problem .Do you think the cause is idle mixture adjusting screw. or the whole carburetor
СообщениеДобавлено: 27 апр 2014, 13:59
СообщениеДобавлено: 29 апр 2014, 01:11
Oopsy.. My mistake, summer tyres is 155/70R12. Anyway, 155/80 slightly greater than 155/70.
There are many reasons for the increased fuel. Maybe it's just a heavy traffic, low air pressure (in tyres) or troubles in the breaks.
Then, try to check the fuel level in the carburetor, ignition angle and the amount of CO/CH in the exhaust. You can find stroboscope and gas analyser (and check these parameters) in the any service station. Adjust the carburetor screws only if ignition angle is correct (4 degrees), and CO/CH is not correct (CO > 0.4%).
СообщениеДобавлено: 30 апр 2014, 00:36
so i don't need to change the whole carburetor
СообщениеДобавлено: 30 апр 2014, 23:27
what is the normal fuel consuming rate for oka
СообщениеДобавлено: 01 май 2014, 01:20
Approx 4...5l /100km (highway), 6..8l (city, heavy traffic). Also, fuel consumption depends on driving style (like with any other car).
СообщениеДобавлено: 02 май 2014, 03:47
how are you Aquinas
СообщениеДобавлено: 14 май 2014, 00:15
i need to know the size of idle mixture adjusting screw for the oka. i want to buy it. and does the one belong to lada fit
СообщениеДобавлено: 14 май 2014, 11:58
Dr amir Lala, sorry, I'm not sure about mixture screw. Idle screw is same to 2108.
All, винты качества Оки и 2108 одинаковые или нет?
СообщениеДобавлено: 15 май 2014, 02:28
finally i found the screw but i hope that this is the only cause which cause the car to stop when i meet obstacle and slow the car
